Has anyone used any of this pipe.
Harvey Ramer
Member Posts: 2,239
I am thinking of trying it but I decided to see if any Wallies had any input first.
<a href="http://www.oilcreek.com/files/support/submittals/heatflex.pdf">http://www.oilcreek.com/files/support/submittals/heatflex.pdf</a>
yep
we're using it. color fades fast with UV exposure. I like that it's flexible and recyclable. only downside I see other than not reforming with a heat gun after a kink is that it's not as rigid as PEX and so in heavy plate situations it can still slide through. it's quiet when it does so, but I still use regular PEX in that situation to avoid the issue.Rob Brown
Well then I guess
I'll try it. They sure make it sound good but I wanted to know if anyone was using it.
Harvey0 -
I have seen...
it in ads for Hydronic alternatives for a few years now....
http://www.hydronicalternatives.com/getattachment/06431cbf-b2da-458a-bc0e-2298c00b88e1/PE-RT-Heating-Pipe-Information.aspx0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
