Has anyone used any of this pipe.
Harvey Ramer
Member Posts: 2,221
I am thinking of trying it but I decided to see if any Wallies had any input first.
<a href="http://www.oilcreek.com/files/support/submittals/heatflex.pdf">http://www.oilcreek.com/files/support/submittals/heatflex.pdf</a>
yep
we're using it. color fades fast with UV exposure. I like that it's flexible and recyclable. only downside I see other than not reforming with a heat gun after a kink is that it's not as rigid as PEX and so in heavy plate situations it can still slide through. it's quiet when it does so, but I still use regular PEX in that situation to avoid the issue.Rob Brown
Designer for Rockport Mechanical
in beautiful Rockport Maine.0 -
Well then I guess
I'll try it. They sure make it sound good but I wanted to know if anyone was using it.
Harvey0 -
I have seen...
it in ads for Hydronic alternatives for a few years now....
http://www.hydronicalternatives.com/getattachment/06431cbf-b2da-458a-bc0e-2298c00b88e1/PE-RT-Heating-Pipe-Information.aspx0
- 117.5K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 402 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 679 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 11 Recall Announcements
