Original Boiler - 1919
and still running.  A "Universal Water Heater", manufactured by the Rotary Manufacturing Company out of Los Angeles, CA.
I've never seen this manufacturer before.  This one serves a 6-unit apartment building in Oakland and we will be replacing it with a Prestige Solo 175.
    Steamhead Member Posts: 18,186
    Rotary doesn't appear
    in Beacon or Hydronic Rating Handbook- it may have been a small company that only sold boilers in that area. Must be a heck of a burner head in there- did you check it for CO by any chance?
    Consulting
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Love those old boilers
    Can you read the "notice to fitter" part of the mfg's plate? It's hopefully good advice.-- NBC
    edited August 2012
    Whoops
    edited August 2012
    Whoops 1
  • MikeyB
    MikeyB Member Posts: 696
    Nameplate
    It looks like it says "Use not less than  (Size of pipe?) Inch flow & Return"
  • I'll check
    the CO and fine print when I go back.
    Both the supply and return tappings are 2"; one supply and two returns.  There is a return manifold at the bottom of the boiler that looks like a twin ell.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,682
    Nice find!
    I looked in Pape-Swift, the Hydronic Rating Handbook, my files and old books and couldn't find this one. It's remarkable how long it lasted. Thanks for sharing, Alan.
    Retired and loving it.
