coils not getting hot
aprilm
Member Posts: 1
the pipes to the heating coil is not getting hot and the AHU are in high humidity alarm. what should I do to get them out of alarm.
I'm sure I won't know the answer, but whoever does will need a lot more info. Like: What is the make and model of the equipment, where do you see the alarm listed? What kind of control is it using. And more may be needed.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
