line voltage and low voltage thermostats
brianl
Member Posts: 2
Need some help please. I have a line voltage system and need to add low voltage thermostat for indirect. Also have fan in the can wired 120volts and ideas???????
brian
brian
More Details
It sounds like you have 2 questions?
For the indirect do you have a line voltage boiler control circuit and are trying to use a low voltage aquastat? Most boilers have a "T-T" terminal for low voltage control.
What are you trying to do with the fan/can?
What products are you working with?
Albert Einstein0 -
Right
I stared at your post for a while last night, before giving up.Everyone is very helpful here, and will spend as much time as necessary. We have to be able to visualize your system.What boiler control are you using?0
- 120 Geothermal
