Hot air to oil?
Jenna
Member Posts: 1
Hello,
I'm considering buying a high ranch in NY with hot air heat-- but I *HAAAATE* hot air heat. Can someone give me a ballpark on what it would cost to covert it to another type of heating system? I have oil heat now and like it.
as usual, it depends
You've given us very little information, and we don't discuss pricing on this board in any case.
If you click on the 'Find a Contractor' link you should find someone in your area that can help.0 -
Fuel vs system
The fuel is separate from the system,you can have steam,hot water or warm air with either oil or gas. What fuel does it use currently?0
