Hot air to oil?
Jenna
Jenna Member Posts: 1
Hello,
I'm considering buying a high ranch in NY with hot air heat-- but I *HAAAATE* hot air heat. Can someone give me a ballpark on what it would cost to covert it to another type of heating system? I have oil heat now and like it.
  • SWEI
    SWEI Member Posts: 7,342
    as usual, it depends
    You've given us very little information, and we don't discuss pricing on this board in any case.
    If you click on the 'Find a Contractor' link you should find someone in your area that can help.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,591
    Fuel vs system
    The fuel is separate from the system,you can have steam,hot water or warm air with either oil or gas. What fuel does it use currently?
