Utica DV200A how to wire in Hotwater tank and zone valve for heat
zwulfke
Member Posts: 8
Hello
I have a Utica DV200A that i need to wire the Zone for Hot water and the zone for the house. The control box looks as if it does not allow me to do this. Is there a way to wire in both zones to the existing box or will I need to get a control panel?
You'd need to use
a suitable relay unit which would operate the zones, and call the boiler when a zone was activated. These are available for zoning with circulators or zone valves.All Steamed Up, Inc.
Consulting0 -
Zone Valve
If you're using a zone valve for heat, you'd use another for the hot water.And use a control such as this, for example... http://www.taco-hvac.com/uploads/FileLibrary/100-5.1.pdf0
