industrial combustion klg
boiler_man
Member Posts: 21
in Oil Heating
I've been struggling with the gas pilot. It seem that every few days I get a call that the burner is in saftey. I replaced transformer and I've cleaned the electrode and checked gas pressure which is 2 inches of water column.
If anyone has a clue as to what's going on please add your thoughts.
Move
this to the GAS section, and Tim will tell you how to fix it.0 -
Need more info.
What is the boiler/burner? BTU rating? Combustion numbers at startup and shutdown?
Give us a little more and then we can help you.0 -
My bad
boiler-man. I didn't look at the subject line. The IC KLG's are pretty basic. Start with the pilot line solenoid. I believe it is an Asco solenoid. Check to make sure that the plunger isn't sticking. Then move to your pilot proving.
I have a manual for that series burner, but I am not going to post it in an open forum. I don't want some facility maintenance guy making adjustments without the proper training.
Contact me with the button under my screen name and I will see if I can get it to you.
Good Luck.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
