Fulton boiler
will smith_4
will smith_4 Member Posts: 259
Hey folks-
Has anyone had to replace the upper and lower refractory rings on a Fulton ICS boiler? We've got one with cracked refractory, and it does not look like it's going to be easy to replace it. Any thoughts or warnings are appreciated-
  • FultonBoiler
    FultonBoiler Member Posts: 1
    Refractory replacement instructions
    Hello Will,
    The Fulton service department provides the work instruction linked below for refractory replacement on all Fulton vertical 4-150 HP fuel fired boilers.
    If you have additional questions, you can contact our service department directly at (315) 298-7148
    http://www.fulton.com/Fulton-WI-SD-009_Refractory-Replacement.pdf
  • Rod
    Rod Posts: 2,067
    Thanks!
    Nice to see that some of the OEMs monitor this board and are willing to help out. That is real customer service!
