Fulton boiler
will smith_4
Member Posts: 259
Hey folks-
Has anyone had to replace the upper and lower refractory rings on a Fulton ICS boiler? We've got one with cracked refractory, and it does not look like it's going to be easy to replace it. Any thoughts or warnings are appreciated-
Refractory replacement instructions
Hello Will,
The Fulton service department provides the work instruction linked below for refractory replacement on all Fulton vertical 4-150 HP fuel fired boilers.
If you have additional questions, you can contact our service department directly at (315) 298-7148
http://www.fulton.com/Fulton-WI-SD-009_Refractory-Replacement.pdf0 -
Thanks!
Nice to see that some of the OEMs monitor this board and are willing to help out. That is real customer service!0
- 125 Chimneys & Flues
