How to replace pressuretrol?
Fizz
Member Posts: 547
Will be putting vaporstat and low pressure gauge on boiler. How difficult is it? Any guidance is appreciated.
Fizz
Fizz
Vapor stat/gauge installation
Can you post a picture of the present pressuretrol location, and then we can advise with more information.
One thing to remember with vaporstats is the importance of a high mounting. As they are so pressure-sensitive, if you were to be using a higher waterline for skimming, the lower-mounted vaporstat would sense the increase in water pressure, and prevent the burner from firing. Therefore it is best to mount it above the top of the boiler, on a manifold above the pig-tail. Don't forget to keep the original 0-30 psi, mounted somewhere on the boiler as it is required by code (even though it is so useless as to be a hindrance to any diagnostics).--NBC0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
