Soft water for 1919 tube steamer make up?
Timco
Member Posts: 3,040
Customer has a 1919 huge tube steamer. It's had a few tubes reolaced and the returns are rotted in a few places. One pipe.
They had another guy tell them a water softening system will make this thing last way longer and will remove deposits from the system.
Opinions from the pros??
Thanks, Tim
Thanks, Tim
Just a guy running some pipes.
way longer
if this boiler is at the stage of tube replacement, then it is not a spring chicken, whose life-span will be increased by some magic chloride atoms from a softener.
better to reduce any abnormal need for makeup water instead of softening.--nbc0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
