rod????steam ?
jonny88
Member Posts: 1,139
hi rod ,i was reading a link you posted about taking a hot water zone of a steam boiler.i got 2 questions.first is where do i put the aquastat as it doesnt show it in the diagram and second is it possible to use this system on a coil for a forced air unit about 24ft above water level.thanks in advance.
That's a Question for Steamhead
Hi- I'm afraid I really can't be of much help to you as being a homeowner I don't have that much practical experience in this area. The person you want to ask is "Steamhead" as he has a lot of experience with hot water zones off steam boilers.. You might want to take a look at his past posts as he discusses hot water circuits off steam systems from time to time.
From what I've learned you may want to use a heat exchanger as while it is theoretically possible to go that high with a single loop, you are far less likely to run into problems and have a more satisfactory outcome if you use a heat exchanger.
- Rod0 -
You can see the basic hookup in this thread
http://www.heatinghelp.com/forum-thread/132567/One-of-the-worst-maintained-oil-fired-boilers-weve-seen
This one is serving an indirect, but the hookup for an air handler would be similar.
Also check out this article:
http://www.heatinghelp.com/article/330/Condensate-Hot-Water-Heating/76/Condensate-Hot-Water-Heating-FAQAll Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
