Lochinvar install photos with centro-therm flue pipe
ScottMP
Member Posts: 5,882
Here's a knight boiler we installed with the Centro-Therm flue piping. we hadn't installed the fresh air make up yet and may not.
I really like the CentroTherm product and we installed the liner down the chimney. Its has a very nice termination chimney cap.
This house has cast iron radiators and she condenses like a mutha.
Happy Home Owner.
Happy Home Owner.
Very nice
Fantastic piping job! Cleanest electrical work too!There was an error rendering this rich post.
nice work
I like the clever expansion tank support. And the Autofill valve:)
hrBob "hot rod" Rohr
expansion
That tank pipe is not as crooked as it appears in the photo.
Nice product HR0 -
expansion
Nice product HR0 -
Nice work
That is a nice boiler install!
Love that ProPress, really speeds things up.0 -
Lovely install
Yes, it is well done BUT, I don't think that your would like to get ge"t no heat calls" next year! Get rid of the neutralizeer cartridge and install a little rubbermaid pot filled with terrazzo stone with an overflow to drain. That neutralliser will pack up in no time depending on the amount of condensate, resulting in a no heat or hot water call.
Been there, amy years ago done that!
Henry0 -
look'n good!
Nice install. Always great to see propress being used.
Why aren't you installing a fresh air from the out doors?
Do you have any photos of the vent from outside the building?
Few pointers: I don't see the hangers on the vent. Without keeping the pipe rigid and pitched you will end up with condensation leaking from the joints.
Next, no lwco?
Last, I was pondering the other day, how does the micro bubbles leave the indirect piping if the spirovent isn't in its loop? Best would be to place the micro bubble separator on the outlet of the boiler, but my guess is that the system wouldn't rid of air as easily. Thoughts?:NYplumber:1
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
