Lochinvar install photos with centro-therm flue pipe
ScottMP
ScottMP Member Posts: 5,882
Here's a knight boiler we installed with the Centro-Therm flue piping. we hadn't installed the fresh air make up yet and may not.
I really like the CentroTherm product and we installed the liner down the chimney. Its has a very nice termination chimney cap.
This house has cast iron radiators and she condenses like a mutha.
Happy Home Owner.
  • STEVEusaPA
    Very nice
    Fantastic piping job! Cleanest electrical work too!
    hot_rod Member Posts: 25,349
    nice work
    I like the clever expansion tank support. And the Autofill valve:)
    hr
  • ScottMP
    expansion
    That tank pipe is not as crooked as it appears in the photo.
    Nice product HR  :)
  • ScottMP
    expansion
    Nice product HR  :)
  • Charles Johnson
    Charles Johnson Member Posts: 24
    Nice work
    That is a nice boiler install!
    Love that ProPress, really speeds things up.
  • Henry
    Henry Member Posts: 998
    Lovely install
    Yes, it is well done BUT, I don't think that your would like to get ge"t no heat calls" next year! Get rid of the neutralizeer cartridge and install a little rubbermaid pot filled with terrazzo stone with an overflow to drain. That neutralliser will pack up in no time depending on the amount of condensate, resulting in a no heat or hot water call.
    Been there, amy years ago done that!
    Henry
  • NYplumber
    NYplumber Member Posts: 503
    look'n good!
    Nice install. Always great to see propress being used.
    Why aren't you installing a fresh air from the out doors?
    Do you have any photos of the vent from outside the building?
    Few pointers: I don't see the hangers on the vent. Without keeping the pipe rigid and pitched you will end up with condensation leaking from the joints.
    Next, no lwco?
    Last, I was pondering the other day, how does the micro bubbles leave the indirect piping if the spirovent isn't in its loop? Best would be to place the micro bubble separator on the outlet of the boiler, but my guess is that the system wouldn't rid of air as easily. Thoughts?
    :NYplumber:
    HydroNiCK
