Is there a steam boiler under 75,000 btu
kevin_58
Member Posts: 61
A customer of mine wants me to convert their carrage house boiler to gas. The problem is the house only has 3 rads, about 93 sq ft of steam. A 75,000 btu boiler is way too big, and that is the smallest boiler i can find. The current boiler is about 30 years old and piped in complety wrong,no header no equilizer, just straight out of the block up to the main. so the boiler needs to be replaced. My only other thought is to rip out the steam and install hot water.
how's the electric service ?
Have you checked Sussman or Thermolux ?
Or you can use hot water to steam. Don't have to worry about low water level on steam side.0 -
There's the Burnham Independance at 62,000 in....
.There was an error rendering this rich post.
Burnham IN3 38,000 btu output
Burnham IN3 38,000 btu output0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
