HBX controls, anyone using them?
tim smith
Member Posts: 2,886
Working on a project that engineer spec'd these. Along with air to water heat pumps, boiler, buffer tanks air handlers etc etc. Any experiences would be appreciated. Thanks in advance, Tim
HBX
I'm in the process of finishing a large install using 4 water to water heat pumps and a back up boiler, all of which heat an 80 gallon buffer tank. HBX will control the whole works. I'm happy with the HBX concept so far- easy to install and plenty of programming options.0 -
Interesting
If you don't mind, keep us posted on what you think. I checked them out after seeing this post. Looks like a nice product and looks like it will simplify control strategy on combi jobs.0 -
lots
I've been using them quite a bit for the past 3 years, just finished a small commercial water to water project replacing a hacked together ddc system with an ECO-1000 + EXP-0100 expansion module + 2 ZON-0500 zone modules + 7 THM-0200 thermostats controlling 2 5 ton ClimateMaster heat pumps & 2 existing Super Hot propane boilers. Works great! I like how you can set the heat pumps to be disabled at either a maximum buffer tank temperature or a minimum outdoor temperature or a combination of both.0 -
Re: HBX controls
Thanks to you all for responding, it always makes me feel better when others have also jumped on board with controls I may be using for 1st time. Thanks again, Tim0
