Infloor PEX tubes at control joints
cgw
Member Posts: 42
In a large commercial reinforced concrete slab on grade, the infloor tubing will be installed on top of the reinforcing. They will be cutting 2" down along the control joints. Do you do anything at these joints with the tubing (other than make sure they are deeper than 2")? Does the slab tend to crack the rest of the way through?
yes.. you need to do more...
Here's something that should help
http://www.wattsradiant.com/support/literature/#/wattsradiant-products-hydronic-radiantpex-radiantpexal/WR_RadiantPEX_ManualThere was an error rendering this rich post.
