Mod/cons and convectors
J. R. Sullivan H&P
Member Posts: 9
I have an established customer who is switching from oil to gas heat.
The existing radiation is cast iron convectors on a monoflow tee system. I wonder what is the minimum water temperature at which the convectors will produce heat? Is a mod/con boiler appropriate for the system?
Mod/cons and fin-tube
http://www.fcxalaska.com/PDFs/BrookhavenBaseBoard.pdf
This study covers this topic in depth,in a nutshell,you'll be condensing the vast majority of the time0
