Buffer Tank ASME
Hovlandstech
Hovlandstech Member Posts: 22
When is an ASME rated tank required and when is it not?
  • furnacefigher15
    furnacefigher15 Member Posts: 514
    Depends on the jurisdiction having authority
    In general though, when the tank is direct fired and over 200,000 btu
  • meplumber
    meplumber Member Posts: 673
    System pressure.
    Also if the system pressure exceeds 50 PSI in some applications and 75 PSI in others.
  • tim smith
    tim smith Member Posts: 2,935
    Re: Asme requirements on storage tanks
    In Wash state, if tank is connected to boiler over 200mbh and or if water temp exceeds 210 f, If tank is over 5 cft in volume. If installed in a place of public gathering or place of worship the volume goes down to I think 2.5 cft. Thats our take on it.
