Buffer Tank ASME
Hovlandstech
Member Posts: 22
When is an ASME rated tank required and when is it not?
Depends on the jurisdiction having authority
In general though, when the tank is direct fired and over 200,000 btu0 -
System pressure.
Also if the system pressure exceeds 50 PSI in some applications and 75 PSI in others.0 -
Re: Asme requirements on storage tanks
In Wash state, if tank is connected to boiler over 200mbh and or if water temp exceeds 210 f, If tank is over 5 cft in volume. If installed in a place of public gathering or place of worship the volume goes down to I think 2.5 cft. Thats our take on it.0
- 120 Geothermal
