furnace door switches
Paul_69
Paul_69 Member Posts: 251
when troubleshooting furnaces with door switches should you by pass it or tape it so the switch stays in. i wondered if the tape was not tight eneough etc. could this give you incorrect volt readings if it was like half way connecting while trouble shooting.is bypassing it the best bet or any other ideas. thx
  • Empire_2
    Empire_2 Member Posts: 2,340
    Generally?
    The switch itself is a snap action switch and is either engaged or not engaged.  it's like a light switch, on or off.  I find it's easier to tape, bypass or what ever so I don't have to use my knee to accomplish this task.  I'm getten old and not as acrobatic as I used to be....:-)
    Mike T.
  • Steve Whitbeck
    Steve Whitbeck Member Posts: 669
    door switch
    I just jam a pocket screwdriver into the gap - wedjing it closed.
