Old thermostat Honeywell T451A1124 in series with circulator
Thinkgene
Thinkgene Member Posts: 1
I`m having my old New Yorker oil furnace taken out and a gas boiler for baseboard heat installed. I have T451A thermostats (really old!) in two zone heating. I intend to keep them. My installer wants to use 24v. I don`t see why unless these thermostats will not control the baseboard circulators. I live on Long Island,and these thermostats are still used widely. I am satisfied with their operation and see no reason to replace. Not broke. Why replace? Comments?
                                   Gene
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    Digital
    is superior, but you can certainly use the existing thermostats if you prefer
  • Big Ed_4
    Big Ed_4 Member Posts: 3,338
    edited April 2012
    T451
    Long Island used line voltage thermostats for hydronic heat from 1960 - the mid 1980s . I assume you have the model with lever on the top since your are satisfied with them ..
    The new gas boiler will run on low voltage though . You can use the line voltage thermostats if you want . For efficancy sake you would want to have a demand control on the gas burner ... Either use relays , install an outdoor reset control .or better yet both.. They help out saving on system loss ...
  • Robert O'Brien
    Longer than that!
    Started in the 50's and went until most new homes had CAC,early 90's. My favorite is very common use of 3 wire,necessitating the use of a RIB relay on a retrofit!
  • Robert O'Brien
    Longer than that!
  • Big Ed_4
    3 Wire
    You mean when they picked up the thermostat at the safety switch ...
