Need to get a gas gun in Bud G115/4, carlin G3B or EZ??
GW
Member Posts: 5,137
Hello, I have not done many conversion burners as of late, I generally pass these off to the next guy, but we have a good customer and I need to convert two. I have put in several G3B, never heard a peep since.
Any opinions about which may be a better fit for the BUD?
Thanks kindly, gary
Thanks kindly, gary
once again i forgot to click the subscribe button
-0 -
Riello
Gary,
We have converted a handful to LP using the Riello 40 series Gas burners. That is the burner that was recommended by Buderus a few years ago. I haven't had any problems.
Good Luck.0 -
Of the two you mention
the EZ-Gas is the proper choice- it can develop more static pressure than the G3B, which is needed since this boiler runs with positive pressure in the firing zone.
I haven't used the Riello, but have heard good things about it.All Steamed Up, Inc.
Consulting0 -
thanks
After I paid more attention to the vendors quote i realized I was mistaken, the EZ was on there twice (their codes make no sense at all), it's just that one had a cover and one didn't (the codes didn't look similar in the slightest). I assumed the cheaper one was the G3B.
Thanks for the help, gary0
