Mega Steam
Dan Foley
Member Posts: 1,268
We installed this Burnham Mega Steam last fall. It replaced on old Kewanee steel boiler that had been out of commission for a few years. The owner was using a wood stove to heat this side of the house.
The other wing of the house had an identical Kewanee that we replaced with a V-8 several years ago (Mega Steam was not available then).
Here is a link to details of this project:
<a href="http://www.foleymechanical.com/2012/03/27/steam-boilers-restoring-an-italianate-farmhouses-steam-heating-system-in-thurmont-maryland/">http://www.foleymechanical.com/2012/03/27/steam-boilers-restoring-an-italianate-farmhouses-steam-heating-system-in-thurmont-maryland/</a>
- DF
- DF
Looking Good!
so was the Kewanee's burner mounted at the rear, like some old Nationals were?All Steamed Up, Inc.
Consulting0 -
Nice !
Looks real sharpe Dan !
Something about a drop header you gotta love it.
Just wondering why the tankless coil and not a inderct?
David
aka DrPepper0 -
Burner
Yes, the burner was on the back of the boiler.
- DF0 -
Aqua-Booster
Thanks for the comments, David. The tankless coil is used as an aqua-bosster during the winter feeding an an electric wtare heater. The boiler is shut off in the summer and the electric tank provides DHW. I agree that an indirect would have been the better choice.
- DF0 -
Re: Mega steam
Real nice looking job Dan. Have you talked to Burnham lately if they will ever consider testing megasteam with gas burner??0 -
Nice and Clean Install
You do your industry proud Dan.
"Almost" makes me wish Lochinvar made Steamers. Of course, any of our water boilers can instantly be "turned into" a steam boiler if....misapplied.That would then mean we would need a manual about the aerodynamics as it flies thru the air...
Best,
Paul0 -
What I'd really LOVE to see...
I think it wold be fantastic to take a Burnham Megasteamer boiler, and drop it in the middle of Lochinvars gas lab, and let your technicians retrofit one of your burner/smart controls on it and run it based on the corelating temperature/pressures of steam, allowing full modulation and see what kind of efficiency could be seen.
I know it would make a lot of people here real happy. I still don't understand WHY Burnham hasn't done this already...
Opportunity only knocks once...
ME0 -
Feeder
Dan, how do you feed water into the boiler? Do you use the #67MM? Do you instruct the owner to blow down the appliance?0 -
Feeder
Hi Paul,
There is no automatic feeder. The boiler is manually fed. No #67 on this one. The boiler came with a Hydro-Level probe style LWCO mounted on the front of the boiler.
- DF0 -
'I still don't understand WHY Burnham hasn't done this already'
I never get the same answer twice when I ask.... apparently someone at Burnham just doesn't want to, and is in a position to block it.All Steamed Up, Inc.
Consulting0 -
Funny Paul.
I actually saw one of your Mod/Cons rocking and rolling due to misapplication yesterday. It was a 501. Scares the hell out of you for a few seconds.
Nice work Dan.0 -
Beautiful install Dan !
Really nice pipework ! Do you have the nips on hand or thread them at the site ? Been begging for a power hand threader for years ............0 -
Pipe
Hi Ron,
I try to order cut nipples for our steam jobs as it speeds up the work. We invariably will still have to cut a few pieces so I still send the Ridgid 300 to the job.
We have a handheld "mule" but it struggles with anything over 1-14" .
- DF0 -
- 110 Chimneys & Flues
- 982 Plumbing
- 387 Solar
