Mega Steam
Dan Foley
Dan Foley Member Posts: 1,268
We installed this Burnham Mega Steam last fall.  It replaced on old Kewanee steel boiler that had been out of commission for a few years.  The owner was using a wood stove to heat this side of the house.
The other wing of the house had an identical Kewanee that we replaced with a V-8 several years ago (Mega Steam was not available then).
Here is a link to details of this project:
<a href="http://www.foleymechanical.com/2012/03/27/steam-boilers-restoring-an-italianate-farmhouses-steam-heating-system-in-thurmont-maryland/">http://www.foleymechanical.com/2012/03/27/steam-boilers-restoring-an-italianate-farmhouses-steam-heating-system-in-thurmont-maryland/</a>
- DF
    Steamhead Member Posts: 18,528
    Looking Good!
    so was the Kewanee's burner mounted at the rear, like some old Nationals were?
    Consulting
  • David Sutton_6
    David Sutton_6 Member Posts: 1,079
    Nice !
    Looks real sharpe Dan !
    Something about a drop header you gotta love it.
    Just wondering why the tankless coil and not a inderct?
    David
    aka DrPepper
  • Dan Foley
    Burner
    Yes, the burner was on the back of the boiler.
    - DF
  • Dan Foley
    Aqua-Booster
    Thanks for the comments, David.  The tankless coil is used as an aqua-bosster during the winter feeding an an electric wtare heater.  The boiler is shut off in the summer and the electric tank provides DHW.  I agree that an indirect would have been the better choice.
    - DF
  • tim smith
    tim smith Member Posts: 2,935
    Re: Mega steam
    Real nice looking job Dan. Have you talked to Burnham lately if they will ever consider testing megasteam with gas burner??
  • Paul Rohrs_14
    Paul Rohrs_14 Member Posts: 80
    Nice and Clean Install
    You do your industry proud Dan.
    "Almost" makes me wish Lochinvar made Steamers.   Of course, any of our water boilers can instantly be "turned into" a steam boiler if....misapplied. :)   That would then mean we would need a manual about the aerodynamics as it flies thru the air...
    Best,
    Paul
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,874
    What I'd really LOVE to see...
    I think it wold be fantastic to take a Burnham Megasteamer boiler, and drop it in the middle of Lochinvars gas lab, and let your technicians retrofit one of your burner/smart controls on it and run it based on the corelating temperature/pressures of steam, allowing full modulation and see what kind of efficiency could be seen.
    I know it would make a lot of people here real happy. I still don't understand WHY Burnham hasn't done this already...
    Opportunity only knocks once...
    ME
  • Paul Pollets
    Paul Pollets Member Posts: 3,672
    Feeder
    Dan, how do you feed water into the boiler? Do you use the #67MM? Do you instruct the owner to blow down the appliance?
  • Dan Foley
    Feeder
    Hi Paul,
    There is no automatic feeder.  The boiler is manually fed.  No #67 on this one.  The boiler came with a Hydro-Level probe style LWCO mounted on the front of the boiler.
    - DF
    'I still don't understand WHY Burnham hasn't done this already'
    I never get the same answer twice when I ask.... apparently someone at Burnham just doesn't want to, and is in a position to block it.
    Consulting
  • meplumber
    meplumber Member Posts: 673
    Funny Paul.
    I actually saw one of your Mod/Cons rocking and rolling due to misapplication yesterday.  It was a 501.  Scares the hell out of you for a few seconds.
    Nice work Dan.
  • Ron Jr._3
    Ron Jr._3 Member Posts: 605
    Beautiful install Dan !
    Really nice pipework ! Do you have the nips on hand or thread them at the site ? Been begging for a power hand threader for years ............
  • Dan Foley
    Pipe
    Hi Ron,
    I try to order cut nipples for our steam jobs as it speeds up the work.  We invariably will still have to cut a few pieces so I still send the Ridgid 300 to the job.
    We have a handheld "mule" but it struggles with anything over 1-14" .
    - DF
  • Dan Foley
    Burner
    Here is a view of the old boiler showing the burner.
    - DF
