Boiler Maintain.
cunam
cunam Member Posts: 13
Hello All.
I'm confused about the way to maintain the boiler.Some people say that flush dirty water out of boiler just once per year because when you feed new water in,the minerals inside water will make the life of boiler shorter,but some people say flush dirty water out every 2 weeks,can you give me idea.Thanks.
  • Waht kind of boiler?
    Steam or hot water?
  • cunam
    Steam boiler
     I use steam gas boiler.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Steam boiler maintainance
    Post a picture here of your boiler, and we can tell you what needs to be done as far as regular maintenance.
    Generally, the boiler drain at the bottom of the boiler will need a small amount drained from it a couple of times a season to remove sediment from the boiler ( a couple of gallons).
    The low water cut off however, needs to be drained once a week. Open the valve until the water runs clear, and this will remove sediment in the float-chamber which could prevent it from shutting off the boiler if the water level should be too low.
    The water in the boiler can stay in it from one year to the next, as it does not wear out.--nbc
  • cunam
    Thanks.
    I guess I know what to do now.
  • David Sutton_6
    David Sutton_6 Member Posts: 1,079
    Inside also
    this guy told me that they dont need to be cleaned..... hmmm think he needs to rethink that statement
    David
    aka DrPepper
