CI Baseboard water in and out
heatingFun
heatingFun Member Posts: 84
For CI baseboards, the water should be bottom in and bottom out or should be bottom in and up out?
My existing CI baseboards are bottom in and bottom out. Somebody told me it should be bottom in and up out. It seems better to me.
Which way is better?
  • Eric_32
    Eric_32 Member Posts: 267
    edited March 2012
    always piped bottom/bottom
     unless on a steam system. Top supply/ opposite bottom condensate drain.
    I have almost always found CI BB to be piped in and out thru the bottom tappings and the upper tapping away from the supply gets the coin vent.
    Here is some good reading material for you:
    http://www.usboiler.net/products/baseboard/baseray/assets/manual.pdf
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Bottom in, top out eliminates need for individual air bleeders...
    You could then power purge from the basement instead of having to visit each individual radiator with a screw driver and a towel...
    If it affected the output by more than 2%, I 'd be totally surprised.
    It will work fine either way. Just makes it easier and cleaner to get the air out from the mechanical room.
    ME
  • Big Ed_4
    Big Ed_4 Member Posts: 3,363
    edited March 2012
    Makes Sense
    You learn something every day , thanks
