how to clean CI baseboard and test joints
heatingFun
Member Posts: 84
I am ready to add a separate zone into my existing one zone system now. I have bought some old (more 20 yrs old) and new (not used) Weil-McLain CI Snug Baseboards.
I found there are some rust dust inside the baseboard. How can I clean them out before connect them? Use Shop-Vac? how about air-compressor? and how to do it effectively?
I have no problem on solder in the past. But this time I plan to test all joints before I shutdown the system and connect the new addition in. how can I test the new addition without interrupt the existing heating? Use my nailer air-compressor? how?
The Air Vent location is on the top close to the end by design. I don't think that is a good place to release air because some water will come out with air and it is hard to catch water there. I am thinking put the Air Vent on the upper side outlet. Is this a valid change?
thanks,
thanks,
Air vents:
You're overthinking the problem. A paper towel is a beautiful thing along with a plastic glass or cup.
I use a nail gun compressor for testing. I test everything and gave for years.0 -
Further note
When pressure testing, limit the air pressure regulator to 25 or 30 psi.0 -
Cleaning
As far as cleaning the inside of the baseboard, vacuum and blow out any heavy particles.
Then get a small pump and some CLR cleaner. Mix 50/50 with water and run in and out of a 5 gallon bucket. Run for a few hours, then flush with clean water till running clear.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
