brazing alternitive
Paul_69
Member Posts: 251
has anybody used this new red goop for ac lines connections. i forget the name something like super pro. you apply it and let it harden then can evacuate and charge ac. it can handle high pressures too. i am drawing blanks on the exact name.
I have
seen either this product, or something similar. I have not used it, and am very skeptical.
Some kind of copper glue.0 -
Can't remember the name
I can't remember the name either, but here was my experience with it.
I was given a sample of the product at at trade show and brought it back to my students to "play with". We decided to do our own field testing...
They created joints on a small piping project using the product (which was not as easy as described by the rep, but that's another story) and then tested the fitting and all held quite well.
As you are all well aware, air conditioning and refrigeration piping is subject to vibration, so the students used the product on a live system. Well, this product and vibration do not play very well together. The joint cracked and leaked.
I sent an e-mail to the company, based in College Point, New York, and posted our results here on The Wall. I invited the owner of the company to respond to our results, as maybe we were doing something wrong. We never heard back from the company.
I am not a fan of cutting corners or taking shortcuts so, personally, I would not use it on equipment that I am getting paid to install, service and warrantee.There was an error rendering this rich post.
how about
how about brazing or using staybrite #8 on ac 410a systems. is silver soddering with softsodder allowed?0 -
how about
It Depends
You need to check the local codes in your area. Some jurisdictions do not allow filler materials with low melting temperatures (below 842 degrees) to be used on air conditioning equipment. For example, it is frowned upon in New York City.
Word on the street says that, in the event of a fire, the potential for firefighter injuries can result if excessive heat from a fire causes low temperature joints to rupture.
I personally do not recommend the use of low temperature filler materials on refrigerant lines, even on the low pressure side.There was an error rendering this rich post.
Blockade
Anyone have any experience using this silver free alloy from Harris?
I have tried it and it seems to flow well and so far hasn't leaked or cracked.
Sure is a lot cheaper than sil-phos.0 -
Absolutely Amazing
I love it and recommend it to everyone. The burst pressure on these joints is super high and you can see immediately if there is a leak. It's self-sealing and can be used directly over soft-solder without having to re-clean and re-prep!There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
