Modcon vent
bld999
Member Posts: 47
Is the vent shipped with some modcons [hy-vent type float air vent] considered a consumable that would typically be replaced after a number of years, or replaced only on failure?
THX
THX
Most
Boilers ship only with the pump (and sometimes not even that). Everything else is up to the installer/designer to order and build into the system0 -
Generally speaking....
hyvents only last a few years. They minerals and junkin the water end up plugging them up. kpc0 -
Vents
Thanks, Guys
I think I am going to replace a couple 6 year-olds if that's the case.0
- 120 Geothermal
