WM Ultra 155 - DH Timer
Bri
Member Posts: 2
I have a WM Ultra 155 w/ direct hot water heater, I want to know if there is a way to use the boiler U-Control to set time that DHW makes hot water; say turning off during night and starting up in the morning.
I bought a Taco clock timer w/ aqua stat but this is to be connected to the pump, but I'm worried how that would work w/ the U-Control ? I'm thinking the boiler would be calling for the DHW to make, and yet the Timer would be cutting power to the circa pump that moves DHW?
There has to be a way the the U-Control can preform this duty? Help please...
kiss
brian,there should be no reason to put a nite set back control on ur indirect tank.the reason being that an indirect doesnt have a chimney. This means that stand by losses are minimal,because there is nothing to siphon off the heat its like putting coffee in a thermos.By shutting it off over nite you'd only make it run longer in the morning,and be adding 1 more thing to break to the control circuit.your fuel savings would be small if any .If you have a re-circ. pump that would make sense to shut off over nite. If you have gravity feeding on your hot water potable side you can insulate it.Or better yet ,pipe in an elephants trunk[reverse trap] to prevent it.0 -
also
In all likelyhood, if you have no hot water drips/leaks, your indirect probably wont even run the boiler over night.There was an error rendering this rich post.
- 117 Geothermal
