hot water baseboard
johnny1234
Member Posts: 11
just figured i need 119 feet off baseboard for a house im building thats 119x600=71,400 btus in how big a boiler do i buy????
Question?
How do you know you need 119' of baseboard?0 -
footage = how big a boiler
sized room by room lxwxhx10=btu's divided buy 600=footage....added all together comes to 119 feet element0 -
What
Method is that?
L x W x H = cubic feet x 10 / 600 ?
Where did that come from?0 -
Oh I see
it now
10 btu per cube and
600 btu per foot emitted.
I still don't know where the 10 btu comes from.0 -
baseboard heat
this house is 300sq. feet 72,00btu's required to heat just sounds low ...am i wrong0 -
baseboard heat
baseboard heat
this house is 3000sq. feet 72,00btu's required to heat just sounds low ...am i wrong0 -
baseboard heat
baseboard heat
baseboard heat
House size:
Are you saying you are building a house that is 119' by 600'?
I have never seen how the heatloss program you used works. But, are you saying that the heat loss program says that a room, 10' X 10' with one outside wall exposure, and the same room with 2 outside wall exposures and a third room with three outside wall exposures all have the same heat loss values?
If so, and you have a cat, and the program is on paper, use it to line the bottom of your cat box. It doesn't work that way. At least I've never seen it work that way. Though, it might work for you.0 -
baseboard boiler size
first floor 7 rooms
5x5x9 powder room 1windowbtu675
kitchen22x14x9btu1window4336btus
study12x14x91window4536btus
foyer10x14x20frontdoor7200btus
off kit eat in10x17x9french doors4590 btus
livingroom 15x8x94050btusbay window
din room18x14x97290btus2 windows
fam room20x14x98100btus
2nd floor
bedroom14x14x91window5292btus
bedroom15x14x91window5670btus
bedroommaster18x14x97560btus1window
walk in closet 7x10x91890btus
masterbath14x11x94158btus1window
bath8x5xx91296btus1window
3000
sq feet0 -
Johnny1234
First off. Only press the submit button once.
Second. Square footage / cubic footage is only part of the calculation.
Do yourself a favor and consult a qualified heating pro in your area. At the very least pay them or an engineer to spec what size heating equipment and baseboard you need.
Would you try to guess at what size I beam to use to hold up the floor over a 30 foot span? I wouldn't either.
I know you want to save some money, but a job done wrong will cost 10 times more to fix later, then it will to just do it right now.0
- 167 Indoor-Air Quality
