Water from overflow
Fizz
Fizz Member Posts: 555
A friend of mine has a hot water boiler which he noticed the pail under overflow at boiler has about 2 cups of water in it every few days.  He said it is not dripping or leaking.  What would cause this?
Fizz
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    It is blowing off on pressure
    Why was the bucket there to start with?
    cell # 413-841-6726
  • Jean-David Beyer
    In my case, I keep a bucket under the blow off pipe just to keep track of whether it discharges or not. Actually, since local code requires the discharge pipe to come within six inches of the floor, it is a cake pan. I wish I were allowed to cut that pipe up so it would end an inch or so above the rim of a bucket.
    I could get a bucket under that pipe now, but by Murphy's law, the bucket would fill up and freeze, and then all hell would break loose.
  • RJ_4
    RJ_4 Member Posts: 484
    relief
    read all the posts on ( BRYAN BOILER  ) one of those solutions should help you.
