Water from overflow
Fizz
Member Posts: 547
A friend of mine has a hot water boiler which he noticed the pail under overflow at boiler has about 2 cups of water in it every few days. He said it is not dripping or leaking. What would cause this?
Fizz
Fizz
It is blowing off on pressure
Why was the bucket there to start with?Cost is what you spend , value is what you get.
cell # 413-841-6726
In my case, I keep a bucket under the blow off pipe just to keep track of whether it discharges or not. Actually, since local code requires the discharge pipe to come within six inches of the floor, it is a cake pan. I wish I were allowed to cut that pipe up so it would end an inch or so above the rim of a bucket.
I could get a bucket under that pipe now, but by Murphy's law, the bucket would fill up and freeze, and then all hell would break loose.0 -
relief
read all the posts on ( BRYAN BOILER ) one of those solutions should help you.There was an error rendering this rich post.
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
