steam boiler
I have steam boiler glass is full of water and usually its half. Radiators are leaking water out of vents. Any ideas
  • albaby
    albaby Member Posts: 4
    steam boiler
    Boiker is gas. 10yrs old
  • albaby
    steam boiler
    I think water feeder is not working letting in to much water
  • albaby
    steam boiler
    Im new here anyone going to help out. I thought this is a forum. Im not a plumber nor a homeowner looking for help. I am a contractor from nj who renovates and builds houses. Thanks for any help
  • over-filling boiler
    by now you have probably found the valve for the auto fill, and closed it. also check to see if the boiler makes hot water, and that part may be faulty as well, in that a coil inside the boiler can spring a leak.
    don't forget to drain off any excess water before running the boiler.
    do a search here for leaking auto feed, and you will find the proper procedure to diagnose, and then repair the valve.--nbc
    Jamie Hall Member Posts: 26,758
    Albaby--
    This is a forum.  I note the time stamp on your post is midnight.  Most of us are either pros or have a day job...  people will get back to you; a little patience is always a good thing.
