3/8 branch pex manifolds?
archibald tuttle
Member Posts: 1,107
all the simple premade copper manifolds I can find locally or on the internet are 3/4 inlet with 1/2 branches. I've got some smaller rooms and bathrooms done with 3/8" pex and I set up the ends to converge for a manifold but can't find one in 3/8". I can get 1/2x3/8 branch tees no problem and I've crimped jobs like this together before, but I like the premade copper manifolds and I'm wondering if anybody has ever found any with 3/8" branches.
thanks,
brian
thanks,
brian
did you check out
Watts? I use them with 3/8 pex.There was an error rendering this rich post.
watts up
steve,
thanks Steve. if you downoad the .pdf and dig in the watts catalog they are there, but nothing comes up on an internet search in terms of drilling down to that part or even knowing they have one, so I'm glad someone knew. You get hundreds of hits for 3/4x1/2 but not a thing for 3/8x. When I put 3/8 in the searcn, I would keep getting pages that had 3/4x1/2 manifolds but also had a 3/8 fitting of some other sort on the page.
I get that 1/2" is the popular loop size and certainly the majority of what I use, but I'm surprised it is virtually impossible to find anyone marketing a 3/8 manifold. i'll get with a wholesaler on monday and see if I can get a couple of the watts ones in. or one of the 4' cut a length versions.
thanks again.
brian0 -
Right church, wrong pew
You have the right one. You can use both 1/2 & 3/8. You just need the right compression fittings. When I get home I'll crawl into the crawl space and get you the right #.
Edit: found an old Invoice should be--3/4" x 3/8" compression, SST20-10There was an error rendering this rich post.
- 109 Chimneys & Flues
- 976 Plumbing
- 387 Solar
- 17 Recall Announcements
