9 units
need to vent a very long main, which valve do you guys recommend
ps  the main gets hot until about 5 feet to where it turns to go vertical
    Steamhead Member Posts: 17,886
    How long is the main
    and what pipe size is it?
    Consulting
  • jrbayside
    jrbayside Member Posts: 81
    9 units
    2 inch main, runs @ 90 feet on the horizontal
    Vent it
    with two Gorton #2 vents. This will get the air out in a super hurry!
    Consulting
  • jrbayside
    9 units
    Hi guys, put in gorton #2 on the end of the main line, but still get no heat from the tee feeding the riser. Any suggestions?
  • jrbayside
    9 units
