Taco pump
Does any one have a problem with the Taco 007IFC F7 pumps ? I have noisy flowcheck. Older F5 is quiet.
  • billtwocase
    billtwocase Member Posts: 2,384
    I don't like or use them
    I much prefer a sweat or flow check valve. Those internal check valves don't last. It's your typical plastic garbage.
  • Steve Whitbeck
    Steve Whitbeck Member Posts: 669
    Taco
    I have used IFC pumps for many years now and have yet to have a check valve  be noisy or fail.  swing or spring checks work great but are quite noisy.  Swing checks clank when they close and spring checks rattle.
  • billtwocase
    I've tried them
    The early version was opposing the impeller, and would pop out and end up like ground beef. They relocated them, but still have had a few problems. There is no savings at that point. These were only developed to save the installer a few bucks, but they can also cost you more in the end. JMHO
  • faneuilmike
    faneuilmike Member Posts: 6
    Taco IFC
    I have 4- 007 IFC on my system for 7 years. I hardly know they are on.
  • Taco
    The 7 year old pumps are F5 or F7 ?
  • faneuilmike
    Taco 007 IFC F5
    I just checked- F5's
