converting 3 phase comp to 1 phase?
tbart16
Member Posts: 23
I have the chance to pick up a large 6 door traulsen cooler but it is 3 phase how would I go about changing it to single phase?
The compressor # copelametic KALA010ATAC / SERIAL # 980-69792
thanks Tom
thanks Tom
What Refrigerant
The compressor you are referencing is an R-12 compressor, although it can be used with R-502 as well. You can get another Copeland compressor with the same configuration (Size, mounting length and mounting height) in a single phase model. However, this single phase compressor is designed for use with R-404A, but you can use it with R-502. If you opt for this compressor, you will need to be very careful with oil selection as well as metering device selection.There was an error rendering this rich post.
thanks
thanks for your help any idea who could help me with such a retrofit Traulsen(cooler manufacture) was unable I have been searching for a copeland website but have been unsuccessful. Any help appreciated thanks again0 -
thanks
Another option to consider.
I don't know what your intended use is for this unit so I don't know if this will be the right solution for you.
It is fairly simple to build a Phase Convertor to create 3-phase from single phase. All you need is the correct 3-phase motor, some run capacitors, some start capacitors a potential relay and the know-how to put it all together. You will however suffer a 10% loss through the convertor.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 989 Plumbing
- 389 Solar
