Winkler Oil fired Boiler
woodandtool
Member Posts: 3
in Oil Heating
I just bought a home. The heat is a Winkler Oil fired boiler. Not running.
Boiler # CIC-$
Serial # E-13428
123,000 BTU hr. water
Does any one know where I can get an owners manual, or operators instruction booklet??
Boiler # CIC-$
Serial # E-13428
Pics will help
chances are the burner is not the original low pressure burner, and has been upgraded.0 -
Winkler Boiler/Burner:
And if it is still the Winkler Low Pressure burner, it will be fun at the old fun house today or soon.
If it is a LP, change it as soon as you can. Let her go run with the pack of old canines.0 -
I remember those Winklers
a very nice, durable, low-pressure pre-mixing burner design. I wonder what we could achieve with their low-pressure system and a flame-retention burner head?
If that is a Winkler low-pressure burner, please don't scrap it! Take some pictures and post them, we can tell you what it is.
Also, where are you located?All Steamed Up, Inc.
Consulting0 -
I'll try to get a couple pictures in a day or two. Yes the burner has been changed. It looks like it was changed a long time ago. lol The burner is outside of the furnace. I know nothing about these furnaces. I bought the house and it was there. Are they steam heat or hot water? The pipes look like they are kinda heavy pipes, that is why I was thinking steam.
Thanks,0 -
Forgot to answer, where I am located. Martinsburg, WV.0 -
Winkler Burners/Venting:
I went looking for a picture of a Winkler Low Pressure burner and I came across this excellent venting exaample(s).
Thought you all might like to see how some do it in the workd of (whatever)
http://www.ductworkinstallation.com/WallofShame/WallofShame2/tabid/405/Default.aspx
Enjoy!0 -
Oh boy
you can't fix stupid!All Steamed Up, Inc.
Consulting0 -
If you can't find someone local
call us. We go to Martinsburg sometimes.All Steamed Up, Inc.
Consulting0 -
- 167 Indoor-Air Quality
