mass sheetmetal law
Paul_69
Member Posts: 251
in Oil Heating
new mass.sheetmetal law, does anybody know a site with info. on where and when you need to pull a permit on residential heating and air conditioning installs and repairs. i am a licensed sheet metal contractor.example when you change out a air condtiong or heating system and tie into exsisting duct with transition or if you add one supply duct or return duct only do you have to pull permit etc.i know if its new construction and whole new system you need this but mainly questions on replacements and minor duct work repairs.very new situation and i am looking for guide lines with residential systems only.
Permit
Paul, I haven't had to pull a permit as of yet. When I spoke to someone about this, i was told that one was not needed for transitioning into existing duct work. If there is any additional ducts run, etc, then I believe you need a permit. I would check with your town's building department, and see what they say. I'm sure it is quite interesting how each town will differ, like most things0 -
duct run
thanks for your input bill.if you were going to run a 8 inch supply duct to imrove heat would you pull a permit for something this small?this whole thing seems crazy. i can see new construction projects and whole new systems but for small duct run or two you are going to pull a permit where every thing else is exsisting?and have it inspected on a system that more than likely has other outdated ducts.and pay a mechanical and or a sheetmetal permit fee for a tiny situation. i dont get it, are they just looking to make money on any job big or small?so what are they looking at if you just add something small, that what you ran is up to code only? there must be some guide lines to go by like the cmr code for burners that states whats required. this is all to new and grey to know whatssuppose to be done to stay out of trouble.0 -
I think
everyone wants to be paid nowadays. It's sad but true. I think we all got backed into a corner with this, and the only way out was to break out the checkbook. I would say that it would need to be permitted. If you find something out share it, as i will here also. The sad part is that it is an across the board thing, and had little to do with residential ducting. From what I gather, it was brought on by some commercial ducting mishaps0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
