Boiler Water Content Comparisons
Dave in QCA
Dave in QCA Member Posts: 1,806
A while ago I gathered a sampling of information to compare the water content of various boilers.  These are mostly in the size range that fit my building, plus or minus a big chunk.  Also added in one megasteam for comparison.
The assumption that is sometimes made that low water content is necessary for energy efficiency apparently does not hold true.  It would appear to be more a matter of cost savings in the boiler manufacture process.
Enjoy!
(This is bad.... when I spend hours putting together the figures, post it on here, and say, "enjoy"!!!  The sad part of the matter is, I know that you all will!  And, I enjoyed putting it together.  It is amazing what some people do for fun!)
Dave in Quad Cities, America
http://grandviewdavenport.com
  • ChrisJ
    ChrisJ Member Posts: 17,048
    Nice
    Nice comparison, a lot easier than trying to go between advertisements.
    I don't think its bad having time to do this.  I treat my steam heat as more of a hobby than anything and I don't think I'm alone.
    Thanks Dave!
  • BrianStMarie
    BrianStMarie Member Posts: 24
    V83?
    Did you happen to come across the Burnham V83 at all? I was just about to post asking if anyone know the water capacity of this boiler. I haven't been able to find it anywhere.
  • ChrisJ
    V83
    I just removed a V83 from my house in October. If I recall it held either 12 or 14 gallons.
  • BrianStMarie
    Actually
    Just found it. V83 is 10.3 gallons for steam, 12.8 for water. I'm assuming with steam, they are measuring to the midpoint of the sight glass. Is that right?
  • ChrisJ
    oops
    Sorry bout that, my memory kind of stinks these days.
    On the Burnham I believe NWL was approx 3/4 of the way up the gauge glass, NOT 1/2 way like others.
  • What patience and dedication have you!
    Those tables of yours are most interesting, but unfortunately my behemoth is not on the list. I notice a big difference now between the present peerless 211a, and the old American standard of similar size: the addition of a gallon of water makes more of a rise in the waterline than with the old. The new design must have much narrower sections, at least in the waterline height.--nbc
