Small bathroom rad stopped heating
I had great heat from this small bath rad, suddenly no heat.
Took off the brand new Hoffman 1A, dumped out a lot of condensate. I guess I should check the pitch to see if is tilted towards the rad valve. I checked inside the opening very clean, the tongue is set right.
Any ideas???
Thanks All,
Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Old Burnham V8 Removal
  • cold rad
    if you fire the boiler without the vent in the rad, can you feel air, and get steam?. have a helper ready on the boiler switch for this!!--nbc
