Small bathroom rad stopped heating
Maine Vent
Member Posts: 130
I had great heat from this small bath rad, suddenly no heat.
Took off the brand new Hoffman 1A, dumped out a lot of condensate. I guess I should check the pitch to see if is tilted towards the rad valve. I checked inside the opening very clean, the tongue is set right.
Any ideas???
Thanks All,
Any ideas???
Thanks All,
Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Old Burnham V8 Removal
404 sq ft EDR
cold rad
if you fire the boiler without the vent in the rad, can you feel air, and get steam?. have a helper ready on the boiler switch for this!!--nbc0
- 167 Indoor-Air Quality
