Water Temp / Boiler Plugging
ChasMan
ChasMan Member Posts: 474
Was reading the instruction manual for the Pensotti DK boiler. There is a note that states:<span style="font-size:12pt">
Allowing the water temperature in the boiler to drop below 160 degrees F for an extended period of time can cause corrosion and boiler plugging. </span>
Are we shortening the life of three pass boilers by using ODR with a low limit less than 160? Will coldstarting boilers plug them up? After all, tests have shown...
  • kcopp
    kcopp Member Posts: 4,562
    something....
    doesn't add up. That may be a misprint.  160F  is pretty high by Euro heating standards.
