eternal gu195s
AFred
Member Posts: 81
Anyone have experience with troubleshooting these?
I put one in yesterday, its locking out, e3, abnormal combustion .
It lites off and surges then drops out.
-andrew
-andrew
gas pressure
Check your incoming gas pressure, Eternals are very finicky like an old cat!0 -
They need to ....
be set up w/ a digital manometer and and combustion analyzer. Even then they do take some time to set up. Did you do that?0 -
gu195s
I have 8-9" wc incoming , it dives to 5-6" on ignition. Then it surges and my gauge gos nuts.0 -
gu195s
It turns out eternal sells a 'rough start kit'.
It consists of a bushing that gos into the air intake elbow and a modified gas pipe from the gas valve to the burner assembly.
Thanks to somone at the local water heaters only, I was able to get my hands on the kit on a saturday.
I put the kit in and she fired right up. Kicker is it really screwed up the o2/co2/co, couldn't get it near spec.
-Andrew0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
