Danfoss TRV valves...
r. perry
I've bought several Danfoss (RA200 1PS) TRV valves and Standard Valve Mounted Dial and Sensor units (013G8250) but find that I don't have enough space between the radiator and plaster wall to install the units. I found an angle adapter on the Danfoss web-site, Angle Adapter (013G1350) and want to know if any Professional Steam people out there have ever used this angle adapter? It seems to be an obscure item as when I called PexSupply to see if I could special order this item PexSupply replied doesn't have it or even ever heard of it and couldn't find it listed in their system. In the Danfoss instruction sheet for the RA2000, it specifically forbids simply piping a 45 elbow and extension. Otherwise, all the other Danfoss TRV valves I've installed work great. A tad on the expensive side but do the job of taming over-heating rooms. I know, I know, I should have checked the clearance before I ordered the valves but the space between the wall and radiator is only about 1/2 inch shy of clearance. Any ideas or suggestions? THANKS!! for any and all replies...
Hmm...
They seem to have it now:
http://www.pexsupply.com/Danfoss-013G1350-Angle-Adapter-for-Snap-Lock-Sensor
Hope it fits!0 -
90 degree?
Hi- Couldn't you use an 1/8 " x 90 degree street elbow coming off the radiator and attach the TRV to that? You might have to rig up some sort of heat shielding as the TRV's the closeness to the radiator might give a false temperature reading.
- Rod0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
