condensing boiler primary secondary piping
bob eck
bob eck Member Posts: 930
anyone using the Caleffi Hydrolink for primary secondary piping. <a href="http://www.caleffi.us/en_US/Technical_brochures/01084/01084.pdf">http://www.caleffi.us/en_US/Technical_brochures/01084/01084.pdf</a>
if you are not using this what are you using?
  • kcopp
    kcopp Member Posts: 4,663
    I have been ....
    making my own. Actually I had Lee @ www.earthlee.com make these up for me. She took down the specs and had them out w/in a week. Nice work. I add a 1.5" cap w/ a good hy-vent, add some screening inside and then go w/ a 1.5 x 1/2 coupling on the bottom. She will even paint them to you liking.
  • nugs
    nugs Member Posts: 77
    Hydronic Separator
    I use them and Taco's version as well.  I quit doing primary secondary over 5 years ago when the light came on and I discovered the wonderful world of hydronic separators.  Saves a crap load of piping and labor.
  • icesailor
    icesailor Member Posts: 7,260
    edited January 2012
    Hydraulic Seperators
    Rule.
    There's never an argument on the spacing of closely spaced tees.
